Climate Control Module Lamp Replacement
So thanks to this forum I replaced the climate control console lamps today. It took about 15-20 mins. I looked around and could not really find any pics of what to expect, so I thought that I would share a few photos for those who like to know what they are getting into before they start.
(1) Remove the phillip head screw in the trash bag hook (lower right).
(2) There are ten (10) spring clips holding the bezel to the body and I started by pulling on the bottom portion of the bezel above the cup holder and worked my way around until all clips were free.
(3) Once the bezel was free, I lowered the bezel and disconnected the cigar lighter and aux power cables at their push tab connectors on the bezel.
(4) I lowered the bezel and rested it on the opened cup holder.
(5) There are three (3) lamps visible on the back portion of the climate control control panel. Turn each lamp 1/4 turn counter-clockwise to release lamp. Remove each lamp
(6) Insert new lamps into holes, turn/align until they press in slightly and turn 1/4 turn clockwise to secure.
(7) Test lamps by turning on Parking Lights
(8) Raise bezel and reconnect cigar lighter and aux power cables
(9) Align bezel with dash using alignment pins and A/C ducts
(10) Push back into place and secure with phillips head screw.
I purchased a set of 3 lamps on Amazon for a little less than $5 delivered.
