cb mount
JP03
New Jersey
Cummins 5.9
any pics of a cb mount in 02-05 3rd gen? Thanks
Stangshcky12
Oshkosh, WI
5.9 Cummins
Just have mine shoved between the passenger seat and center console
Stangshcky12
Oshkosh, WI
5.9 Cummins
It worked out perfectly for me. I just have a small uniden. I put a cigarette lighter plug on it and just have it plugged into the center console and I ran the coax out the back passenger side door so it out of the way. No holes drilled or wires spliced
Flashback
Made a bracket that uses the 2 bolts that hold the center seat down. It comes out, bends up and CB mounts to it. Ran the coax through a slit in the carpet to the back passenger under-seat storage and out through a grommet to the bottom side of the truck, up between cab and bed to antenna mount that goes over the front bed rail.
I'm going to remake it, clean it up and have it powder coated.
I'll try to get some pics.
HemiBabe
DFW
Sounds pretty cool!
quietpeen
2021 TRX
Hellcat
custom consoles kick ass
KSMegaOwner
2006 MegaCab 3500
Cummins
I used the CB that has all the controls on the mike, and mounted the other box under the drivers seat. The mike with all the controls works great and I have it hanging on the cig lighter. The coax runs under the carpet and out the back of the cab through a grommet so I didn't have to drill any holes.
Hemitom
NorthEast/Elkton Md (Newark,Delaware)
Hey Flashback, any pictures yet???
cwakefld
Central IL
This is how I did mine. It's just shelf brackets cut off and sanded smooth so there are no sharp edges.
Nickxxxr
Near Reading, PA
Maybe some of you guys can help me... I got a peaked and tuned cobra 29 Tgats has been put in every truck i had for about four years. Im ready to put it in my 2011, but i have a couple issues. I will be mounting it in front of bench seat on floor faceplate up. Idk where i should mount Mic holder. Also don't know where to run whips. I don't want to drill holes in my new truck.. Any opinions. Im just afraid to drill holes in new interior and bed so i have been holding off on it for a year. Of i get some good input i may install it this weekend.
Btw i don't like the magnet whips that are ten foot about the roof of truck....
Sent from my SAMSUNG-SGH-I897 using Xparent Green Tapatalk 2
