Changing Gauges Blue
korby05
Delta, PA
5.9 Magnum
Alright guys I have a question for those that have done it. I know how to change all the bulbs and everything but my question is that since everything else in the truck green would the blue gauges look out of place. I was going to change my climate control over to blue also but I was told that I can't since I have the dual climate control. I have the setup like the one in the picture
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
It will be out of place but it depends on how retentive you are w/ dealing with it. I am not fussy when it comes to the interior so i deal with different gauge colors which are no way close to my cluster but others are very particular to make sure all is matching so its really up to you.
Stangshcky12
Oshkosh, WI
5.9 Cummins
From what I remember I think you might need to use a whit bulb on the climate control, blue doesnt go through the red so it looks stupid
There is also a blue tint that alot of guys use, its called rouscloux or something like that
You put it over your gear indicator, overhead etc and it looks really good
Stangshcky12
Oshkosh, WI
5.9 Cummins
This stuff: Rosco Laboratories 74 Roscolux #74: Night Blue | Full Compass
I dont see why you couldnt do the climate control
K
korby05
Delta, PA
5.9 Magnum
I believe it has to do with the selectors on the right hand side. I know i have to use a white bulb or it will look dumb without the red showing up. I've had the overhead apart countless times trying to fix it. All in all I'll have to get a new one, Mines the EVIC so it really isn't that cheap
quietpeen
2021 TRX
Hellcat
good info cody. I know in the cluster you can use blue led's
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Would the LCD display work for red tint?
BlackedOutHemi
DFW, Texas
2012 & 2012
Haha. Might as well try it. I'm attempting a completely red lit interior.
