justin13703
Hopefully someone has seen this before because I don't even know where to start. My recirc door works ONLY when the ignition is on, but the engine is off. As soon as I turn the engine on, the door moves somewhere in the middle of the recirc box, and kind of just jerks back and forth. It never makes it to one side or the other. As soon as I turn the engine off and have just the ignition on, the door begins to work just as it should and goes fully from one side to the other when the button is pressed.
I tried to make it as easy to see as possible in this video, in the beginning the engine is off and as you can see the door works perfectly. Then I turn the motor on and the door starts to jerk around and not work correctly. Then at the end of the video I turn the motor back off and the door starts working again. Has anyone ever seen this before?
3F6A3159-6DF1-4B45-96C5-0879956D7E92.mp4 Video by justin13703 | Photobucket
