I believe this is connector C201. It seems that the corresponding harness is for a sunroof and lighted vanity mirrors. I did not test any pins for power on this socket.
On the other side of the dash, behind the glove compartment is a five or six-pin plug. Depending upon options, it seems to be for possibly a mirror microphone/auto-dim mirror and clearance lights. It's number is C206 and in case anybody needs an interior switched light, I checked all the pins and Pin 2 is definitely on the light switch.
EDIT: I tested it and three of the small pins are IGN ON-switched. None seem to be switched via the lights and I presume the larger pins are for a sunroof. Might need a fuse or relay to energize those pins.
