Map Light bulb type
DrewRam
5.7L HEMI MDS
DrewRam
5.7L HEMI MDS
Cool Thanks! Anxious to try this now
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Pop one of those in all three light sockets and it should fix any flickering or malfunctioning. Haven't had a problem since then.
DrewRam
5.7L HEMI MDS
Do yours still dim when they turn off?
DrewRam
5.7L HEMI MDS
Popped in the resistors and they still ain't acting right
Everything seems to work good but I still can't use the map lights unless the key is in the ignition
via DroidX (Tapatalk)
BlackedOutHemi
DFW, Texas
2012 & 2012
Mine work when key is out. That's odd. Ran 3 resistors?
DrewRam
5.7L HEMI MDS
Yea they don't flicker anymore but if I push a map light to turn it on when the key is out/off it flashes for a very quick second and turned off completely. IDK maybe I should try a different resistor. Are you using the exact same ones I linked earlier?
BlackedOutHemi
DFW, Texas
2012 & 2012
Just to make sure I wasn't lying to you. I just tried turning on the bulb with the keys out. They both work. Do you have the same bulb as me?
DrewRam
5.7L HEMI MDS
No I have the HP ones in there now. I forgot they weren't the same damnit that might be it.
I might try some different resistors
