jjantz2000
- Oct 13, 2016
- 2
- 18
- 2003
- 5.7 Hemi
Hi all,
Bearing in mind that ole reliable has been in service since 2003, some of the interior accent lights have begun to burn out. I have already replaced all the instrument cluster lights (due to a incorrect bulb size from the dealership), and am working to replace the climate control panel, and all door lights. I recognize its cosmetic, but I strive to keep the truck as fully functional as possible. When I went to the dealership to get the bulbs for the climate control panel, I was given instrument cluster lights (Apparently these bulbs are not listed with my model truck through MOPAR). I have found the correct size bulbs through research (Part # 05013815AA for anyone who could use it, shown below). I wanted to know if anyone has swapped the lights in the overhead computer module control switches (picture 2, 4 labeled buttons), and if the bulbs match the bulbs below, or if any bulbs exist. I have not had a chance to pull the upper console since hard wiring the left map light.
Thanks for the help.
