Just so happens I just pulled mine out so I can paint it black.
Like calidodge said you need a flat blade.
Push down on the dash right in front of the seam so you can slide the screwdriver under the front section w/o forcing it. Once your under there just pull up untill you pop one of the clips.
After the first one you can work the rest with your fingers. Just be careful because the edge is kinda sharp. I think you could cut yourself fairly easy on it.
The clips up against the wind sheild are in at an angle toward the windshield, so pull back toward you for those. The clip on my pass front corner was stubborn but a hefty tug pulled it out with no damage.
