Schelling53
- Dec 16, 2016
- 8
- 4
- 2003
- Hemi 5.7
I have a tapping noise in my 03. 135000 miles on it. I did valve springs and seals. I heard these have issues with the cams wiping a lobe. Can anyone elaborate on that? Also if that's the case what are the chances the cam bearings are bad? I can pull the heads and do a new cam lifters and push rods but I can't do cam bearings on my own. Also it appears I'd have to pull the engine to do the bearings. I have found only 1 person anywhere on line that welded a cam bearing to the cam and spun it. I don't have any oil pressure issues and I assume I would if I had a spun bearing? Seems like low miles to be worrying about anything like this. Just plan to do a new cam lifters and push rods for the low cost of roughly 750 in parts. if someone can tell me otherwise I'd greatly appreciate any input. From my understanding the cam bearings usually far outlast the rest of the engine. Thanks in advance!
