I installed the new throttle body. The plug wire connector was a little hard to get in. I had to use a little extra force, then it went in. I think the locking tang on the side of the throttle bodies wire connector was a little different. In any case, the response is still the same. No change. I previously purchased a crankshaft sensor which I did not install. So I had my son help me replace that. Still no change. Same bad response. This thing is blowing my mind. I'm thinking of putting some type of additive in the gas tank to see if the reponse gets better. Something that will help to clean the fuel injectors. This all started with two codes popping up a while back which I posted here in the forum. The two codes were: P0203 and P0172. Then for what ever reason, the codes cleared by itself and never came back. So, now I'm thinking this may still be the problem. If it is the problem, why aren't the codes popping up? This is really strange. Any suggestions on what to check on next, or what type of additive I can use to clean out the fuel injectors? If the response gets better, then I can replace the injectors. Thanks for your support, Tommy.
