twilliams33
- Mar 14, 2017
- 5
- 0
- 2003
- 5.7
Have a 03 Dodge ram 5.7 that was running great until last week and had a small backfire and started missing. Got it home and hooked a OBDII scanner to it and it said I had a misfire, misfire in cylinder 6, O2 sensor bad and crankshaft sensor. Check plugs and they need replaced so I changed all plugs and swapped the coil pack with the one on cylinder 4 and changed the crankshaft sensor. Still has a terrible miss and won't run but just O2 related codes. While working on it and trying to get it to run I got the flashing lightning bolt. Had cleaned throttle body about 2 weeks prior to this happening. I removed and cleaned completely and lightning bolt gone but still won't run right. Tried to drive to shop to get checkout today and when I hit the hard top I noticed my brakes didn't work. I went about a mile and it hit limp mode and red lightning bolt. Restart no lightning bolt and here I am now talking to you. OBDII gave 2 codes.P0038 and P0306 is all I'm getting right now. Plugs were not smashed just need replaced since they have 195k on them. I need help bad.
