My truck has 85K miles on it and its only averaging 13MPG! WTF! This is not cool. Its all stock. Is there any options out there for increasing MPG? open it up with a k&n intake & filter and full exhaust and a chip maybe? Any suggestions? Thanks.
When was the last time the plugs were changed? Remember these engines run best on Champion Copper or NGK Nickle plugs, BUT they are only a 30,000 mile plug...however, they are cheap to replace yourself as you can gernerally purchase the champions for less than $18 from Napa or the NGK's for less than $21.
Some other things to try are...clean your throttle body well and IAC...get some mass air flow sensor cleaner and clean you intake air temp sensor well. Make sure all your tires are at proper PSI. Also, at 87,000 miles, I'd go ahead and replace your upstream O2 sensor.
Other than that, there's not much to do. My reg cab/short bes 2005 Ram has the 4.7 too, I have an AirAid MIT intake on the stock air box with a K&N filter, I run a Flowmaster 40 series single in dual out muffler dumped, I have 3.92 gears, and I only have 59K miles on it and my average with mixed driving is 17.5 MPG's, and thats with a light foot.
I will say this, idling AND running the RPS's over 1650 in OD, will kill the MPG's in our generation 4.7...I try to idle as little as possible and whenever possible on the highway I set my cruise right at 60MPH, which is 1650 RPM's. If I am on a really long intersate run, I can start seeing 21-22.5 MPG's on the EVIC, but as soon as I hit city traffic, I can sit there and watch it drop.
The only "chip" that is going to really do anything is a Superchips programmer...the Superchips 3865 to be specific. Any "chip" you find on eBay is simply a resistor, and wont do jack.
Now, you can add whats called a power wire to your intake tube.
Does the GFORCE performance chip really work? need some opinions bc it gives you 4-7 more MPG and 30 more horsepower..
