06 started and drove fine to work - no start on leaving work thru crank sensor code new sensor no start track it that getting 5 volts thru ground wire - replaced cam sensor- throttle body - accel pedal- opened wire harness from pcm to sensor no damaged wire evident - any ideas/ checked wiring diagram ground wire goes thru about 6-8 more sensors. on key on position thottle light flashes - will start but rough idle only immediately throws crank sensor code
help
help
