andr3wxmma
- Jul 31, 2016
- 8
- 3
- 2007
- hemi 5.7
The truck used to only pop out of reverse when backing up. The box around the selected gear would disappear and if you kept giving it gas it would jump back into reverse and even spin the tires a bit.
Coming home from fishing this weekend the check engine light came on with code p0750 (solonoid issue and went into limp mode.
I've heard you can try the connections on the harness and sometimes that will fix it but I can't seem to figure out what plug in it is.
Does anyone have some suggestions before I throw it in the shop and spend money I might not have too?
Thanks in advance.
Thanks in advance.
