Hi all,
First time posting but been browsing for awhile. Seen a lot of similar threads to this one but none quite what I'm hearing.
Recently I noticed a rattle noise coming from the passenger side in the engine compartment. It only seems to happen at a certain level of acceleration right before it drops into a lower gear, when I am giving it easy throttle. If I give it more throttle the noise goes away I believe, hard to say 100% as my cai is a bit loud to hear over. Doesn't happen if I rev the engine in park/neutral, only when driving.
It isn't a tick from what I can tell. Sounds almost like some rocks being shaken in a can, but slightly less pitchy if that makes sense.
Also hearing a knock when I first start my truck before it heats up. Sounds similar to the rattle but more just knocking with the engine rotation rather than a fast rattle. Not sure if they are related.
I've tried checking for anything loose and used a screw driver to listen around but can't pin point it. Just filled up my truck with a higher octane and put some sea foam in, but so far after 100km no difference. I did recently put the cold air intake on and the noise either started just after, or just became noticeable without the resonator box on. Can't hear the noise with the window down either.
Was going to check for oil in the throttle body next but haven't had time. Would like to avoid going to the shop only to be told they can't fix it or don't know what's wrong. Any help would be appreciated.
