1500-1800 RPM Engine shudder
dawe-o-
Jasper, AB
Hi guys, I have 2004 5.7 Ram 1500 and today I did 400km round trip through the mountains. When I drive in 5th gear in around 1500-1800RPM thats around 80-90Km/h and start to slowly accelerate (mostly up hill, but happens on flats aswell) just gently enough that the transmission doesn't kick down a gear. The engine shudders, stutters, chokes. The best I can describe it, that it feels like when you drive a standard and you rev too low on high gear, so the engine feels like it will stall.
It is only happening on those revs, once you get over 2000RPM it is smooth as usually.
I tried to search forums and I found out it can be everything from spark plugs, ERG valve, high octane fuel, to lifters, so I just want to ask here if anybody had the same problem.
shanonnew
Kansas
Just checking to see if you were able to figure out what the issue was? Thx!
Scottly
Safety Harbor, FL
HO 6.7 Cummins
So...one arseclown makes a single post 5yrs ago and some other poor guy with (probably) the same issue desperately searches for an answer. My suggestion: Make a new post.
