Thomas
what should I run in the 1/8 mile 04 rcsb 5.7 k&n cai efan sonax line pressure booster power wire no cats and a flowmaster 355 gears 275/45/17
Depends on your DA and track, when ya gonna give it a try.
That cam alone wont get you there becuase its a mostly mid upper end range cam low end is compairable to stock.
Wow! I have 20's on my quad cab and 3.92's, and you were almost a full second faster. Does superchips make that much difference or am I having a problem I should look into?
it won't let me change any thing but tire size should I get a scdsp will be fine if you can adjust shift/tranny points. Some early 04 year builds are not able to modify shift/tranny options.
i think with good weather you might be able to get better then a 9.6 i ran a 9.4 at 75mph in my old quad cab on 20s but it had 3.92 gears and a superchips
For shift points yes but do you still want a custom tune for the cam or just run the SC 91 canned tune? if custom then you need to stack SCT on top of SC or if you are daring then DSP on top of SC. SCT custom tune (through Sean) has 7k limiter when manually shifting but keep the SC shifts when in D.
