mantis300
- Oct 14, 2017
- 6
- 0
- 2002
- 4.7
The one that's in it has 186,000 and the used has 115,000. So if I rebuild what I have, it still has 186,000 miles along with the tranz . The engine I'm getti g comes with the trans and transfer case for 1,500 bucks already pulled.Why not just fix the engine you have? If it was me, that’s what I’d do, instead of installing a used engine when you don’t know the history of its maintenance or how it was treated.
Sent from my SAMSUNG-SM-J727A using Tapatalk
Yes could be, but I would have 2 of each to put one motor together. One already out and another in. I can work on the one before removing the old? Let's just say I take the time to remove the heads. It's possible the heads are warped or the block is cracked. If that's the case. I have a second motor to pull from. how much are new heads?Even then, for all you know it’s been a rough 115,000 miles. It could suffer the same fate.
The amount of work spent swapping motors is gonna be just involved as replacing a couple headgaskets.
Should be ok as long as the engine is from 99-03 starting in 04 they changed from a 16 tooth reluctor ring to a 32 which would give you issues unless you swapped it over.
