2003 1500 heating issues/problem
1500 heating problem solutions
  • Thermostat fixes problem
    Votes: 0 0.0%
  • Flush radiator to fix problem
    Votes: 0 0.0%
  • Heater core leak
    Votes: 0 0.0%
  • Turn off secondary cooling fan
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Jimbo82
I have a 2003 1500 with a 4.7 that does not blow hot air. I have flushed the radiator, flushed the heater core, changed the thermostat, and still no heat. Any ideas?
bhonshell37
Washington
Does the heater core get hot once the engine reached operating temperature?
Sent from my SM-T550 using Tapatalk
J
Jimbo82
I don't know without taking apart the dash, but the heater core supply lines are allows hot, which makes me assume the heater core is hot. I back flushed the heater core and got a palm full of sand and grit, but it didn't fix the problem.
bhonshell37
Washington
Sounds as if your core may have a partial blockage
justin13703
MD
If you flushed the heater core and it flowed fine, and both heater hoses are hot, then chances are the heater core is ok. You could have air in the system and it also could be a blend door issue.
J
Jimbo82
How do you get air out of the line?
JPT
NY
2015 Big Horn
If you follow the upper radiator hose to the engine block (front driver side) there is a hex plug. Open that slowly, as the air settles there. If you can park on a steep hill (head up) it will help. I had to do this several times.
Do this with the engine COLD, and OFF. Just do it a few times.
Eknopps
Scottsboro, Alabama
Magnum 4.7
Hey JIMBO82,
Were you able to fix your Heating problem ? I have the same issue with my 2003 Dodge Ram 1500, 4.7 engine.. I've done everything you said you did but still No Heat ? I have Not tried the air out of line thing one guy said, I was wondering if you tried that and if you did did it work ?? Thanks
LoneWolf3574
Hey JIMBO82,
Dude, 7 YEARS and he has only posted 4 times.
