tcoffey
- Apr 27, 2015
- 3
- 0
- 2003
- 4.7 V8 Magnum
So, my question is should I just trade in my truck and spend the mula to purchase a new vehicle after having a blown head gasket? I bought my 2003 4.7 V8 ram used at 115 K. Not long after I had a blown head gasket. Fortunately I had purchased an extended warranty which covered a lot of the work. I had both heads resurfaced at a machine shop and the gasket replaced. (I did see white smoke coming out the exhaust before it blew, but am not entirely car savvy so yea it finally blew, also yellow "****" was on oil reservoir cap.) I'm told it was a coolant leak into the cylinder etc. After the all the repairs, my truck runs pretty well at 141 K now. However I do hear a slight ticking noise that is really almost inaudible but I'm super observant now (or try to be) that I've been through the entire process. My dilemma is should I sell the truck being it is still under the (decent) extended warranty? I'm nervous that I have some serious oil sludge issues and other problems from the head gasket failure that will end up costing me in the long run. I'm not sure if the valve job as my un-trusted mechanic calls it, was enough to fix the problem. Not sure what to do, or what else I need to repair from the head gasket blowing. He did not say anything about looking at the main bearings, whatnot that might cause big problems in the future. Many thanks for any replies!!!
