First off, tried the search and looked all over the internet. Cannot, and I stress, cannot locate this problem.
The truck randomly stalls sometimes in the driveway while warming up. When I come to a light. If I brake to a stop. Most of the time after I get gas.
No codes. Ran a OBD reader on it to check vaccum, voltage, loads, misfires, etc. Everything came back fine.
So Far I have replaced:
- PCV Valve
- IAC Sensor
- Map Sensor
- Cam Shaft Sensor
- EGR Valve
- Cleaned Throttle Body
- Reset PCM
- Checked Battery (13.0V), (14.4) when running.
I am at a lost for words. I have no vaccum leaks, fuel pressure seems ok, runs great on the highway and roads. It just seems to loose idle and stall erratically. I can get it to come back up if I give it gas, but it dangerous pulling onto on ramps and such.
Any ideas or input is greatly appreciate.
- PCV Valve
- IAC Sensor
- Map Sensor
- Cam Shaft Sensor
- EGR Valve
- Reset PCM
