KPietriyk
- Aug 29, 2015
- 65
- 15
- NE Pennsylvania
- 2005
- Hemi 5.7
Hello,
Been searching but unable to find an answer. My truck makes a whining "gear-ish" noise when moving, changes pitch with wheel speed. Just replaced a ton of stuff in the front end, plus a starter, muffler, and tires. Took my mechanic for a ride today, we were hanging out the windows trying to pinpoint the source, sounds mid-line, not wheel noises. First thought of wheel bearings, all good- then diffs, both full of clean oil. No play in either drive shaft, so probably not a pinion bearing. Next step is transfer case fluid level check/change. Transmission fluid is full and clean. I drive very little now and since I've had the truck (maybe 3k miles/year), but starting next week I have to drive about 100 miles/day for the next 4 years. No money for new transmission/truck, so hope it's something simple like adding fluid to the transfer case. Didn't know if anyone had come across this issue before, I'm not a fan of "poke and hope" mechanical repair.
