3.7L Replacement Advise
pshojo
I am new to Dodge family, left Chevy. Bought a 2005 Ram 3.7 with a Stick for $2000. Thought it was a deal, knowing it starts hard, either valve dropped or main bearings.
Would you replace the 3.7l with low mileage engine or would you do a reman? Any suggestions on who to go with or which companies to stay away from with remans?
What other upgrades would you do while everything is out?
thanks.. Newbie in Iowa.
P
pshojo
Do you know what years the 3.7L will interchange with 2005?
What Reman companies do you recommend?
Johnnymac2k6
Ohio
2007 Ram 1500
I sell atk reman engines at work. We have good luck with them. Even have some guys buy them for performance builds. Message me if you are interested
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
you sir have my attention now
Johnnymac2k6
Ohio
2007 Ram 1500
Here's the killer. just looked and they're $3600-3700 with freight and core. and the core is $500. So you have to make the decision if a 3100 reman engine is right for you.
I can get almost any engine on the books...the issue is remans are expensive...
So take this with a grain of salt, as i have no idea how nice the rest of the truck is, but MOST people back out on purchasing a 3,200 engine....for a $5000, vehicle? know what i mean?
in your case you may find a pullout 3.7 at a boneyard for $200-500.... but you're then buying alot of unknowns. all for you to decide your best option.
Demon-HeMi
Houston
I should re-phrase....Some guys buy the reman ATK hemi's as a starting point, and build from there... we don't sell any performance 3.7s lol.
no i just need a good 3.7 for my project truck!
aheeejd
4.7 V8
Do you sell the 4.7 also? I have 03 ram 1500, with 240k on it & a blown head gasket.
Sent from my LG-ls990 using Xparent Green Tapatalk 2
aheeejd
4.7 V8
Yes thank you, I will keep in mind, I'm going to call a few places local & just to let you know I'm having to save $ as I go, have about $1000 now
Sent from my LG-ls990 using Tapatalk
Lil_Ram
Power tech 3.7L
I beleive it's a strong motor and take my 35s and lift kit like a champ. Just needs some waking up.
Jba shorties I've had no luck with camshafts might have to have one custom ground. Airram.com has some stuff for us though not a lot but some search jeep side found ported throttle bodies before don't remember where though.
I recently contacted hemifever about tuning and SCT no longer supports the 3.7l either so tuning might have to be custom tuning
P
pshojo
3.7 to 4.7
Do you sell 4.7l? Anyone do this swap?
P
pshojo
who has swapped out to 4.7l? i was reading were the computer can run both 3.7 & 4.7 and all the accessories will bolt up? what experience do you have with this?
P
pshojo
what other companies do you recommend rebuild 3.7l?
P
pshojo
Help. Can I use 3.7L out of 04 Dodge Dakota? I'm thinking I might need to swap water pump and intake to make this fit? Thanks
Lil_Ram
Power tech 3.7L
Make sure it's the same set up as current
