4.7 swap ?
Notthatlow
Broken Arrow,OK
What all years/models can I get a 4.7 out of with out having any issues.... I searched for some answers but I can't really find any answers
MarkV
Ontario, Canada
4.7 Magnum V8 NOW with Moose Power
I have not come across anything talking about 4.7 engine mounts differences....
ercmesser
Tampa, Fl
If you have an 2002 4.7 you need to find an 02 motor. Time points and computer are different.
xb1230
Hobby Mechanic
South Shore of Montreal, QC, Canada
Best way to determine your application is to take the valve covers off.
Look at the timing gears and find a replacement motor with the same cam gears.
The rest of the assembly can be swapped from the old motor to fit your application. This may involve Exhaust and intake manifolds, engine mounts, and some sensors.
A salvage yard should be able to tell you of the motor they are selling you will fit your application regardless of it's origin.
Hope this helps.
Notthatlow
Notthatlow
Broken Arrow,OK
I pulled a 4.7 from a 01 Durango and from what I found they are the same I was told that the PCM plugs need to be the same so that's what I went off of so hopefully it all mounts up and runs good if not I have 30 days to find the right one at least lol
Notthatlow
Notthatlow
Broken Arrow,OK
Well we got the old motor pulled and drained the oil needless to say it wasn't very pretty now we just have to swap the fuel rails over and put the other motor back in!
Notthatlow
Notthatlow
Broken Arrow,OK
This was supposed to be the second pic lol we drained close to 5 gallons out
MarkV
Ontario, Canada
Looks like your on the right track!! Hope it all works
icywhite
ill be doing the same thing soon how hard was it to separate it from the trans.
Notthatlow
Notthatlow
Broken Arrow,OK
It wasn't to bad actually just make sure you get all the bolts and unbolt the torque converter.....I forgot the T/C when I pulled the junkyard motor :)
