Ok so i got this 2003 1500 4.7l about a year ago. Has 180k miles and when i got it i decided to change some gaskets and replace the timing components with new ones. After putting the timing chains and tensioners on i noticed the passenger side timing chain had alot of slack in it even though the tensioner was fully extended.
People told me it was fine. So after putting it back together and starting it, it had a LOUD knocking sound because the loose chain was slapping the chain guide and the tensioner itself was fully extended. Well i left it because the truck ran normal. But after a month the chain guide broke because it was getting smacked up and down by the loose timing chain and when it broke it bent all my valves and had to rebuild the head.
So after fixing the head and putting all new timing components on again for the 2nd time the same passenger side chain is still loose. It has alot of slack in it even when the tensioner is fully extended. I cant seem to figure out why there is so much slack in the chain. And if i leave it like that then all i get is a LOUD knocking sound when the truck is running. Ive watched a ton of videos of people timing these motors and i timed it all correctly but still have a ton of slack in the chain.
Has anyone ran into this issue before and fixed it?
