6.1 heads on a 5.7?
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
What all needs to be changed to run 6.1 heads on a 5.7 block?
OklaHemi
new age hemi
weedahoe has a lot of knowledge on this pm him
truckin151
2013 sport
Pretty sure you need the adapters to run them cause the ports dont line up right. And I "think" you also need to be able to tune them but am not 100% on that one
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
as far as i know its new heads, coils, plug wires, intake, conversion plate that moves one of the pulleys out of the way and maybe another thing or two? Its in the 4-digits for only a few hp gains, not worth it for most
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
He is talking the heads guys not the 6.1 car intake. The heads will bolt up far as I know but the compression ratio is changed and make LESS power from a preious thread I have seen that Stu had comented on. To know for sure I would hit up Sam on here or drop a line to Inertia to see. Do you already have a set of these heads on hand? The exhaust ports are a mismatch also so you would have to get adapters or change your exhaust again along with haveing a mismatch on the intake side.
Redtruck-VA
Redtruck-VA
Virginia
Actually I was looking at Moe's 6.1 heads, they have a custom chamber that raises the compression to 10.4. So was thinking since the heads are reported superior to the 5.7 heads and can raise the CR also, perhaps a person would be money ahead to go with them. The exhaust mismatch I understand can be corrected with a grinder. This leaves the intake and any relocation of other parts that are in the way. Just looking at "what if's"......
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
will the ports match up? i've heard it takes some modifying in order for them to work on a 5.7 block
Redtruck-VA
Redtruck-VA
Virginia
I have no personal experience but from what I have read the exhaust is a pretty simple fix with a grinder. The intake mis-match fix is to use a 6.1 intake manifold. If anyone has done this pls pitch in.
mcraezy87
Greg, I'm actually in the process of piecing together this setup. I still need to find the small details such as what pushrods to use, and what can be done to lower compression ratio. Either thicker head gaskets or opening up the combustion chambers themselves. Ive heard Moe's performance has some input on this.
As for the intake port mismatch, I've got the 6.1 intake manifold. And as you mentioned before, the exhaust port can be solved by opening up the header.
I'm having trouble finding the A/C and Alt. relocation brackets, another key element for installation.
There was a guy on DT I met a year or two ago that ran an entire 6.1 top end on his ram. I can't remember his name and haven't ran across him anymore.
So far I've got the intake manifold assy, and heads. So I guess the main hardware is taken care of.
Also, SUPER anxious about your megasquirt installation!
mcraezy87
Wow. Just realized this was my first post since I joined last year....
Iflyjets
Hemi 6.1
I'm glad that you posted. I just installed a complete 6.1 in my 03 Ram and can find a good solution for the exhaust mis match.. If I grind the port on the 5.7 manifold i would run out of material before I was done. I was able to port my truck manifold and get a close match but I. Am stuck on the exhaust problem.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Greg, If you Mill your current heads .30 thou you'll Gain 10-15 HP and be Married to 91/93 Fuel (only 8 custom rods required, not sure which can look it up ). I just made a deal with a Guy for a Spartan and Inertia Perf Heads (Milled .20) for 1.2K barely used and in my research I read alot about the Milled way of raising Compr and squeezing some HP for the price of Gaskets/Bolts and Machining. The 6.1 Heads on a Truck 5.7 might work well as the Intake doesn't die out like the Cars.
Not to Jack but I may keep the Crazy Spartan in as the estimated end Numbers are higher for RWTQ on the CS vs the Spartan but Spartan has 20 More BHP. Once I decide the Gear Ratio for my Getrag LSD then I'll choose weather or not to swap out Cams or sell it Off. May get the 3.91's as in the new Burn-Out Car (Mopar11 Charger).
Good luck modding and BTW your new Plastic valve cover and coil upgrade should shoe right onto those. Adapters can be found at Shop Hemi or HHP.
Also you could see if 6.1 SRT Factory Headers and/or midpipes can be modded to the Truck, those are plentiful to find at low cost too (Like-D- Mentioned Jeep=Better).
Iflyjets
Hemi 6.1
I have a set of 2013 6.4 Jeep manifolds and can tell you they will not fit on a 03 4x4 ram. I was Able to port my truck intake manifold to fit the 6.1 heads.
mcraezy87
IS the 6.4. exhaust bolt pattern the same as 6.1? Or is it an overall bulkiness issue?
Redtruck-VA
Redtruck-VA
Virginia
This thread has been asleep for a long time. Glad to see the new posts. Good information.
Thanks,
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
How did we get talking about the 392. The long IAT works....lol.
Redtruck-VA
Redtruck-VA
Virginia
Ahh the thread is about heads and manifolds bolt to heads.
