hemi04
Well i started out with a blown up 5.7 when i bought the 2004 Dodge ram 2500 4x4 in march of this year. I pulled the engine out and disassembled the engine to the bare block. I had a 6.1 rotating assembly, so i decided to put it to use, as others would say the impossible! due to cylinder wall thickness. Bored the 5.7 out to a 6.1 bore, and installed the the 6.1 internals, crank,pistons,rods, oil pump,6.1 cam and push rods and injectors. Installed a set of 5.7 stage 3 big vales heads. Built and custom tuned by King Motorsports!
