6.1 SRT8 Ram Swap
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Also wondering how its running. You running the stock PCM or a file? Your more displacement with more lift on the cam but being the 6.1 cam is either 115 or 117 LSA depending on what you took the 6.1 out of it should run it after learning alill.
I
Iflyjets
Hemi 6.1
It's running good on the stock tune. I did use the 5.7 injectors and throttle body so the EEC won't get to confused. I plan on trying the SRT8 throttle body but the one I have was damaged in shipping of the engine.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Do you have access to a sniffer to make sure the 5.7 injectors are not starving the motor for fuel on the topend? They are alill smaller for sure, I swapped out my 5.7 ones for 6.1 injectors when I went to the new head/cam setup.
I
Iflyjets
Hemi 6.1
Did you need to change the tune to use the injectors?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I have a Dyno tune for the truck with a DSP. If a stock 5.7 were going to run 6.1 injectors you take a chance of washing the cyclinders. The 6.1 is 25 more CI then the 5.7 hence the more fuel. You might be ok, just not sure if it will start to starve for fuel on the topend is why I asked about getting it sniffed.
RamHemi5.7
Gilroy Ca
2013 Quad Cab
Hemi 5.7 8 Speed
thats cool man! No way I could do that to a truck here in the communist state of california!
I
Iflyjets
Hemi 6.1
I spun a bearing on my 5.7 and when I was looking In The junk yard I found a 2006 charger with the 6.1. I picked up the engine for only $800 with only 20000miles on it. He had no idea what it was worth!
PCA4208
Albuquerque, New Mexico
That's a great deal!! But then again 4 months of work is well, work. Haha
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
You STOLE that motor. Hell since they no longer produce the 6.1 the cores on the block alone are around $1k-$1,500, the heads are $500.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Well done. Wide band should tell you where you are at. AeroForce Interceptor gage would show trim figures. I use a 05 fuel pump upping the pressure from 48psi to 58psi, that might be all you need to compensate.
mcraezy87
Which engines sensors did you use? I assume the Rams since that's what signals the pcm will be reading? And is it still running good so far?
mcraezy87
I think this guy just teased us and ran! Or I suppose he's out having too much fun to be internettin'!
Redtruck-VA
Virginia
Stuff to think about would be the 04+ fuel pump regulated to 58psi instead of the 03's 48psi. Now my question would be are the 03 injectors larger than the 04+ 5.7 injectors since the fuel pump pressure is lower? Or does the 03 PCM compensate for the lower fuel pressure, which would then mean there is a lot of adjustability in both fuel flow and PCM tune ability. Just thinking out loud... Good job on the install..
Lethal Hemi
5.7L
badass sure does make me wish i didnt sell my 426ci and still have it on my ram. O well i did by a 6.1L intake and TB for 250 which is getting ported so i can put it back on my truck with some heads ported to match the 6.1L runners
LightningRaper
Brooklyn NY
Viper 8.3
Do you think it was worth it in the end? What kind of numbers you putting down on dyno?
I
Iflyjets
Hemi 6.1
Sorry it been some time since the swap.
I have 7000 miles on the new motor and have had no problems. I ran the stock injectors and Throttle body from the Ram with no problems and it pulls hard.
The hard part was making the relocation brackets for the AC and Altonator
I used the truck timing cover and ground the top down to make some room for the intake. But I also had to make spacers to lift the intake 1in.
I used pacesetter shorty headers and ground the ports to mach the 6.1 heads.
I had to make a y pipe and move the cat 14in back.
If I had to do it again I would not use them. Lots of work to make them fit.
In the spring I'm going to try some 6.1 jeep headers and make a new y pipe.
I also used all of the stock sensors for the truck and the belt is from a 98 v8 with the ac delate .
I have not had it on the Dyno but did race a 2011 mustang 5.0 and got him by 3 car lengths :) with the stock tune.
On important note is to make sure the 6.1 you have has no clutch bearing in the back of the crank !!! It took me 2 day to figure out why the engine would not mate to the Trans!!
mcraezy87
Dude, that's crazy awesome info. Still have a hard time believing, (no discredit to u, mopars pcms kinda suck), that it all works with stock computer. An 03 no doubt!!! Now I GOTTA find a 6.1 bare block to complete my setup!
B-g-K
Upstate NY
Ecodiesel
Damn... You outran a mustang with the coyote in it? They're no slouch, that's awesome.
