6.1 SRT8 Ram Swap
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
IMO, there is a lot to like about a blower, compact and reliable. They are also expensive. Superchargers can run bigger more efficient intercoolers and are versatile in applications and are easy to install and upgrade. They are more affordable than a blower. Turbo's usually take a lot of fabrication for your specific application making them more difficult to install. If i had good welding skills then hands down a turbo would be my choice. Boost is addictive so you've been warned...
ST-8
I'm at that point. Trucks got a cam, full exhaust, gears an lsd, an a 115k mile 5.7 that I feel still has some life in lol.. Anything I wanna do to this thing now is in the thousands, a 12 sec street truck is pretty sweet
Redtruck-VA
Virginia
Agreed, making the old truck fast does takes a lot of work. If you don't do the work yourself it can get expensive. And of course plan on replacing the transmission with something that can take the abuse.
jotin
your mom
It would be cool to do the 6.1 swap. I'm currently in he beginning stages of converting my 03 system to the 05 setup. Just can't find a good PCM, I'm just gonna have to suck it up and buy a new one and have my vin programmed to it. But I'm at a point too where I can't really do anything else thats not gonna be a crap ton of money. Headers , customer exhaust, cam/lifters, valve springs pushrods, tune, gears. I'm loving the truck, just really want to get the 05 setup to really bring out the power.
Redtruck-VA
Virginia
The 05 pcm swap is key to tuning the mods. IMO it's worth getting it done so you can move forward with the other mods. I spent years fooling around with the 03 pcm and it was mostly wasted time and money.
jotin
your mom
Luckily I found this out early. Now it's just a waiting game to get some extra cash to get the new PCM. I can do the programming and wiring myself. Already got my new TCM connector. Just gotta get the PCM switched so I can switch the connector. Gotta also add the new 02 sensor wiring as well
Redtruck-VA
Virginia
Once you have the donor plug, pcm and 02s it won't take you but a few hours.
Not having to do the tcm, I did mine in a couple of hours.
ST-8
I know that feeling an I already got the headers, cam, an gears done already.
DesertWagon
Reading this thread gives me hope for my 08 Powerwagon.
ST-8
4wd hemi RCSB is a good base
Ghost1990
California
Has any body else done a srt8 6.1 swap on a 2003 5.7 hemi that can help me out ?
chrisp2493
Always Modding
Warren, OH
392 Hemi
What kind of help are you looking for? There’s quite a bit of info on doing a bigger Hemi. It’s only limited by your time and budget
Redtruck-VA
Virginia
First swap to a 05 pcm. Then you can build a stroker motor or use a newer motor but you are limited with 2008 or older since these will have a 32 tooth tone ring thats compatable with the 05 pcm.
Ghost1990
California
Help as far as knowledge from you guys like what is needed for the swap to a 6.1 like do I need all the harness differential and all different tranny I wanna keep the 4x4 but will swapping affect it
Redtruck-VA
Virginia
Ok, complete the 05 pcm swap. Then we can talk about transmissions swaps. You will need a 03 and 05 service manuals with pinouts to get started. If you are doing the work yourself, it'll be a lot of fun. If you are paying someone to do the work it will be very expensive.
Ghost1990
California
I would be doing the work I have the original Manuel I believe I just bought I last april and it’s nice and smooth a lil high mileage but seems very healthy
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Tuned in.
Redtruck-VA
Virginia
Then you will have a lot of fun and great truck. Don't get in a hurry and go one step at a time. You are starting at a good time as others have already done both the 05 pcm and 46rh swap in 4wd model 03's. You won't have to reinvent the wheel
Chris is about to become your best friend.. as he has done the pcm swap, plus built a stroker motor.
