AFE Throttle Body Spacer mounting equipment
PCT
2019 2500 6.4
Northern California
I had a AFE silver bullet throttle body spacer on my truck, and had to take it off because i get it wasnt legal in California. So i went to remount it and realized the shop took it off and through the mounting brackets away. is there a way to buy just the mounting equipment not the spacer its self?
Thanks
i have 2004 4.7 BTW
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
Contact AFE they might be able to help. And how can the spacer not be legal??? The paperwork says it is carb compliant, which means it should be legal in all states.
PCT
PCT
2019 2500 6.4
Northern California
So i called afe, and they directed me to Taylor cables, so i ordered the equipment, so i will let you guys know if that works. its was 25$ plus 7$ shipping
PCT
PCT
2019 2500 6.4
Northern California
i know i am ressurecting an old post... i sold that truck and bought a ford 6.0... only owned it for 9 months then went back to ram!
Anywho, taylor cables, give them a call if needed and order the spacer caple extentions they were 25$ and they will give you a new sticker for CARB
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
You do know that throttle body (TB) spacers do absolutely nothing for electronic fuel injected engines right?
Except maybe make it whistle.
A ported TB is a different animal all together allowing more air in; but the spacer just spins air going into the intake manifold--no fuel to mix with it, no better burn rate etc., just the same volume of air spun around.
HemiLonestar
MD
I was gonna ask why you didn't just leave it off. Unless you're putting nitrous nozzles in it or you just like the noise...
PCT
PCT
2019 2500 6.4
Northern California
it was installed on the truck when i bought it, and it did sound pretty dope.... but i dont have the truck anymore, so maybe i should have...
hemihustlin
Montreal
Why did you give up on the ford so soon?
Egr cooler leaking? Lol :p
PCT
PCT
2019 2500 6.4
Northern California
haha Oil cooler.... so i was either going todo oil cooler egr cooler, clean the turbo, fix the HPOP, dummy plugs and stand pipes, and it was either going to be 2k in parks, 4k at a shop, or i spend 8k and do head studs, so i traded it in for 13k and got a truck under warrenty and i know i can work on and not worry about....
