Air Filter's for OEM Air Box
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Is anybody running these aftermarket air filters for the OEM in air box's like K&N, AEM, AIRAID, etc...? I'm tired of dropping $30 bucks on a WIX every 3K at oil change and I have the filter cleaning kit for my crankcase filter so I just assume get a cleanable air filter and be done. I ran one before, but I wasn't running a tuner or anything so I didn't really pay any attention to performance, the only downfall I can see to this is the wait time to clean, dry and re-oil, what's your opinion?
DesertWagon
Each to there own. They all work pretty well. You just got to make sure it seals well every time. I usually get the K&N filter since they are at every parts place. I'm currently using an Aftermarket dry filter on a tube away from the motor. And it seems to be working good.
justin13703
MD
My personal opinion, is do not use an oiled filter. They can be over or under oiled and not work well or intoduce excess oil into your intake. Plus you have the extra work of actually oiling the filter.
Aem dryflow filters are about the best out there. No oil, but they are still cleanable and reusable.
Markcuda
Clinton,Illinois
2015-Laramie-1500-CC-4X4
KandN drop ins are pre oiled, last a life time,(million mile warranty) clean every 50,000 miles, lightly reoil and ready again.
justin13703
MD
The aem/amsoil filters are the same, but with no oil involved.
Don't get me wrong k&n filters are also good filters, but oiled filters are pretty much old technology at this point. If there are cleanable dryflow filters available for a certain application, it makes more sense to use one of them vs an oiled filter.
Markcuda
Clinton,Illinois
To each their own, that is why they make different flavors of ice cream.
SilverStreak88
SilverStreak88
Houston, Texas
5.7 Eco Gasser
So it's recommended to do a dry filter? I always wondered what was considered "to much" or "to little" oil when re-oiling the filter.
justin13703
MD
Yeah. I've personally used the aem dryflows through a couple of the cleaning cycles. Just spray em with cleaner, spray them off with water, let it dry and reinstall. They pretty much look and work like new after the cleaning.
SyN
6.7L CTD Owner
Tornado Alley
2017 4WD - Tow Prep Pkg - Off-Road Pkg - 3:42s w/Anti-Slip
6.7L CTD
Since the 500 mile mark I have run the AEM (Dry Flow).
Down Stream tube/Top of Air Box/Throttle Body has been totally spotless of any dust particles or residue.
100% satisfied!
SilverStreak88
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Put the AEM Dry Flow in, she feels a little better, but don't really know without some actual numbers.
EWC88
Southern NJ
Thank you for posting this, need to change mine and was curious what's a good filter if you have stock box. Will order AEM one now!
1Popeye
