Missbhavin
- Jan 24, 2017
- 4
- 1
- 2006
- 5.9 Cummins
Hi,
I'm new and maybe you all could help. My alternator is going out and I also needed batteries for my 06 2500 with 5.9.
I put two batteries on and bought the alternator (auto zone tested it bad). I've been working alot and I drive a truck so I've been only using my truck about twice a week for a month now. I hook up the main battery to the charger when not in use and it shuts down when charged. Yesterday I got home too late tried to make it with the lights off driving on shoulder with flashers. It died finally and I had a friend jump me. I had to turn the key on and off to prime it because i guess it ran the power so low. I made it the 8 miles home and barely through my gate when it died again. I took both batteries off and started charging the main on that's on the passenger side. It's charging well. I tried the other and the green charging light won't come on and it pulls power down in the charger and cuts the charger off. I tried changing the charger to to 6v which it stays on then and shows its at 85%. ???
I don't have a volt meter (can't find it). I checked the water in that battery and it looks fine
