Battery running down when parked on 07 Ram 1500 5.7L
jeffstoy
After coming out to a dead battery a few times, and thinking I must have left something on or the battery was not holding charge, I finally realized that it was always when the truck sat for a bit. After the last time, after charging the battery, I took off a terminal, hooked up an ammeter and found something is drawing a whopping 1.2 amps instead of the normal 30 ma. or so, needed to hold the memory on the radio and computer. I disconnected the output cable from the alternator but that was not it. I pulled a few fuses but it was getting late. Tomorrow I stick in a battery cutoff switch until I solve this. Anybody had a similar problem that they fixed? Thanks.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
I'm no help but will be following ! Please update what you find ! Thanks
tncruiser
kingston tn
5.7hemi
don't forget the obvious ,under hood light? and cab lights would only show up at night WITH the door doors closed (don't ask how I know)
brian j
J
jeffstoy
brian j
I confess. I have left one of the over head map lights on a time or two. There is no under hood light. I was kind of surprised at that. It is an SLT and it has most of those little extras. The dome light is not switchible and goes out when it should.
J
jeffstoy
It I discovered that the vehicle has a shutdown pattern. It draws 1.2 A and then 0.6 A and slowly toggles back and forth. Then it drops to the expected 13 ma. I did not time it but it is not very long. The original problem was that the battery was just shot. I replaced it. I lost track of how long it had been in there, over 6 years. I got more than my money's worth
