Biting the bullet on a edge TC today
badblackram06
badblackram06
MS
Thanks guys. Ill have to look into the larger cooler and a gauge. I wish dodge had put a temp sensor on these transmissions.
badblackram06
badblackram06
MS
Really? Didnt know that. Why doesn't diablo or superchips read the gauge? My trinity just reads it as -40.
Blackram
I always wondered the same thing about the tuners. But for whatever reason the ai does read it.
truckin151
2013 sport
yup my ai reads my trans temps. the trinity should read it too, wonder if the setting isn't setup on it or if it needs an update.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
This is the 1 ton cooler I installed a few years back. The truck has never gone over 180 degree's no matter what I'm doing with it.
badblackram06
badblackram06
MS
It's possible. Ill have to look at that tomorrow. As far as updates it has the latest.
badblackram06
badblackram06
MS
That looks good. Do those coolers hook straight up to the existing cooler lines?
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Yes Sir, and thats the Biggest One right there, as said before mine is the smaller 2500 yet bigger than the 1500 but when I ordered it used at the wreckers it was too late and the price was right.
That ai stuff is Cool. On my Magnum RT, I can now read the Trans Temp thru the Evic as part features of my Tranzformers shift Kit (as well as shifting from the steering wheel, line Lock, Burnout, and Launch Modes, to name a few!) and trans settings imput via a program on my Lap Top.
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
that one ton cooler is awesome. strait plug and play, no mods required. I had both that and the deep finned PML pan. I wouldn't recommend doing both in a cold climate. tranny barely ever reached 150 down in san diego. but it sure kept temps in check towing the 11k lbs horse trailer over a large mountain range.
Blackram
The one ton is a great mod. Keeps the trans nice and cool and you can't beat how easy it is to install.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Badblack yes the lines are the same, might need to bend them some to get them to line up like I did but slips right in. You can put some hardware on the top clips to hold them in since the 1500's come with the mount but no hardware.
badblackram06
badblackram06
MS
Nice. My current cooler was patched because a rock punctured one of the cooling fins a few months back. Another good reason to upgrade.
Thank you all for the awesome information.
badblackram06
badblackram06
MS
I just checked my trinity and it has the PID for the trans oil temp but its just showing -40 degrees like i mentioned. I tried setting the minimum value to 50 degrees and max value to 250 but nothing changed it. I have pulled up a lot of post where other ram owners are getting this same -40 reading. So it may be a trinity issue that they haven't figured out yet.
truckin151
2013 sport
only thing you may notice with the larger trans cooler ids your engine temp might raise about 5-10°. I have a 180° t-stat in mine and after the larger trans cooler it runs about 185-190°. Basically it's due to the larger cooler taking up more surface area on the radiator which restricts the air flow for cooling. not a huge deal but if you monitor engine temps, be aware of the small increase in temps.
truckin151
2013 sport
that sucks
badblackram06
badblackram06
MS
I was curious if that was going to be the case. It does make sense.
And yes it does suck.
truckin151
2013 sport
it's not a huge jump in temperature, just noticeable enough though if you monitor it.
Redtruck-VA
Virginia
Yep, engine temp went up a few degree's and ride's at 188 degree's.
Blackram
Same here, riding around 174 with the larger cooler.
