Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Engine & Performance
Sponsored Ads
Register to remove these ads.
Broken Exhaust manifold Studs
This is a discussion on Broken Exhaust manifold Studs within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category!
Register to remove these ads. It's free! Hi All, Thanks to the forum, I found the exhaust leak on my ...
Reply
Old 02-05-2012, 03:45 PM   #1 (permalink)
JeffBeck's Avatar
Ram Year: 2004
Engine: Hemi 5.7
Default Broken Exhaust manifold Studs
Hi All,
Thanks to the forum, I found the exhaust leak on my 2004 5.7 Hemi. Broken Exhaust Studs. Both sides.
If you have seen any of my other posts, I bought this truck cheap but it needed lots of TLC and has been getting it since I bought it. I think the broken studs are signs of hard offroad use. (also got that from forum)
I see by the parts list it is a combination of studs & bolts.
So my first question is... Does anyone have any good advice on removing the exhaust manifolds?
Second question.. Maybe kind of an opinion poll... Once I remove the manifolds should I assume other studs have been stressed and change all the studs, risking breaking off a stud in the head that did not need to be changed? or just replace the broken studs and leave the rest alone?
JeffBeck is offline   Reply With Quote
Old 02-05-2012, 08:25 PM   #2 (permalink)
KGBIGCOUNTRY's Avatar
3rd Gen / Site Mod
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Default
Welcome bud. You can soak the remaining bolts and try pulling them out. The collectors are not to bad to undue at the back if the mans, the retained nuts might break but can replace them with reg nuts. I would swap all of them and if its ever in your plans toss in a set of shorties in there.
__________________
RamForum.com Moderator
Its Tweaked & Twisted
Crazy Spartan on a 112lsa Thumping It, PWR Heads Opening It Up, Coated Pacesetters Doing The Rest, Tuned by Spooldu with DSP
Powed and Tuned by King Motorsports
KGBIGCOUNTRY is online now   Reply With Quote
Old 02-05-2012, 08:35 PM   #3 (permalink)
03MopaRamman's Avatar
Ram Year: 2003 Forgottens
Engine: Hemi 5.7 (1 of 2)
Default
Yep and do it when the Truck is cold. Can Take the inner fenders out too will make it easier. There is a liquid wrench Gel that works good and doesen't run off when sprayed!
__________________
6.1 Cam/Springs/Rods/Oil pump-SC3865-85 mm Ported TB W/Grnd-K&N-Pwr Wire-E-Fan-Hooker Headers-Flo Tech Y Pipe-Magnaflow 18" Dumped-B&M Shifter-TCI 2600 TC-Transgo HD w/Resist-TMR Delete-HD Cooler-Auburn LSD 4.56's-Mopar Cover- Modest 3" Lift-SRT Hood-RF Tactical Grille-Blk Lights-Cab Lights-OEM Hella Fogs- PWR WGN Flares-Black Bed Caps-Rails & Mopar 4" Step Tubes w/5x Amber-1OAK Steel Rims/285 Duratracs-Gator Mudflaps-Rolling Tonneau-Leather. Next:Hellwig-35's.
03MopaRamman is offline   Reply With Quote
Old 02-06-2012, 10:06 AM   #4 (permalink)
JeffBeck's Avatar
Ram Year: 2004
Engine: Hemi 5.7
Default
Thanks for the input!!
Old 02-06-2012, 07:12 PM   #5 (permalink)
Ram Year: 2004
Engine: Hemi 5.7
Default
Replace all the studs. Everytime they are torqued down they stretch and are weakened. The heating of the block and manifold also puts stress on the studs. That is why they snap. When buying replacements, make sure you get the proper grade or go one better. This is one place not to skimp on quality.
Wanderer is offline   Reply With Quote
Old 02-06-2012, 07:21 PM   #6 (permalink)
Ram Year: 2003
Engine: Hemi 5.7
Default
Is there somewhere you can buy a compete replacement set of studs/bolts? I'll be upgrading to headers soon and would like to have these handy.
ybnormal70 is offline   Reply With Quote
Old 02-06-2012, 07:30 PM   #7 (permalink)
glass3222's Avatar
Ram Year: 2005
Engine: 5.7 Hemi
Default
First, it is very common for the manifold studs to break on Hemi's so I would not attribute it to abuse.
Second, like others said, soak all of the studs with liquid wrench/wd40/pb blaster the night before you are going to take them off. I would also have a set of vice grips handy for when you take the manifolds off. You should be able to grab the broken stud with the vice grips and spin them out of the head.
Last, it sounds like a great excuse to get headers since you have to take the manifolds off anyway
__________________
Gone but not forgotten: 2005 1500 4x4 SLT Sport, 5.7 Hemi
2007 Dodge Durango SLT AWD 4.7, Superchips, BFG Rugged Terrains
glass3222 is offline   Reply With Quote
Old 02-06-2012, 08:38 PM   #8 (permalink)
hawk02's Avatar
Ram Year: 2005
Engine: Hemi 5.7
Default
Shorties time!!!!!!!!!!!!!!!!!!!!!!!!!!!
hawk02 is offline   Reply With Quote
Old 02-23-2012, 11:57 AM   #9 (permalink)
JeffBeck's Avatar
Ram Year: 2004
Engine: Hemi 5.7
Default
I finally got around to getting the job done. I removed the wheel wells and soaked the bolts overnight with PB blaster. I removed them the next day. The two rear bolts on both sides where broke off at the head of the bolt. Leaving lots of bolt exposed to get a hold of them and take them out. Everything came out easily, except for one.
One bolt forward of the rear two on the passenger side was broke off in the head. You could not get a drill on it easily to use an extractor, the frame had a mount for the upper control arm in the way. I tried many methods to get it out without spending too much money, finally I bought some left hand drill bits & a right angle drive for my drill. It came out while drilling, I did not even need the extractor.
The truck sounds much better now, thank for everyone’s input.
Old 02-23-2012, 12:03 PM   #10 (permalink)
05singlecabHEMI's Avatar
Ram Year: 2005
Engine: 5.7 HEMI
Send a message via Yahoo to 05singlecabHEMI
Default
Wish i saw this thread eaelier. I have all the nuts and bolts. For the exhaust manifold i think. Havnt counted them but its a lot. Lol
__________________
night vision HID kit, Pacesetter LT headers dual exhaust flow master 40series dumped before the axle, vararam air intake, 1.5inch leveling kit, Dakota AT^2 tires, plastidipped wheels. raceland 3" cutout, SC 3865 tuned, rocket wire, aeroforce gauge in a SRT 10 pillar with A/F ratio, color matched gill, plasti dipped bumpers.
05singlecabHEMI is offline   Reply With Quote
Reply
Bookmarks
Tags
broken header bolts, exhaust leaks, exhaust manifold
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2nd Gen Manifold Swap infernoredram General Discussions 1 02-04-2012 05:01 PM
CTD exhaust manifold ramhunter9 For Sale 1 01-31-2012 05:46 PM
exhaust manifold recall ledge2ez Tech Info 18 10-26-2011 02:21 PM
Cracked exhaust manifold-Aftermarket Recommendations? wolfwalker 5.9 Common Rail 1 12-12-2010 01:34 PM
Wanted: 5.9l exhaust manifold wolfwalker Wanted 0 12-11-2010 08:45 AM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
