Cam install
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
About to replace my cam and I have all my bits and pieces together but for a couple spare valve spring keepers. Anyone with a couple spares laying around and would send them to me I would gladly buy them from you. Pls PM me for address.
Thanks,
Redtruck-VA
Redtruck-VA
Virginia
It's all good fun..
ST-8
Didn't josh hook you up with some?
ST-8
Ah makes sense.
HemiLonestar
MD
Thanks,
What are you going with?
Redtruck-VA
Redtruck-VA
Virginia
Going to give the PPP Track Warrior a try. The Grand Cherokee's seem to do well with it. 214/224 .587/.573 113lsa
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Greg, You dont need spares Man, just need to find any you drop. I can send you my cool little pen sized magnet its 6 for six! Looks like a nice Cam on paper. Hope all goes smooth. Danny
Redtruck-VA
Redtruck-VA
Virginia
Danny, you would really appreciate my assortment of magnets. I got one that looks like a mine sweep and a little pen size one that takes both hands to pull lose.
HemiLonestar
MD
I saw your other post before I saw this one lol, oops.
Redtruck-VA
Redtruck-VA
Virginia
I lost air on a cylinder and dropped a valve.... Got the head off and retrieved the valve. Finished installing the new springs on that side. Going to town to pickup gaskets and bolt this morning. If it ain't one thing it's another. As for loosing air, all I can say is don't close the shop door on the hose. Hope to be back on track today or tomorrow. I'm not going to push. The good news is the local dealer is starting to become a good source for parts.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
**** Happens Greg. I once realized that you need to take out the air valve in the compression tester hose I was using for it to actually pass air into the cylinder. luckily I realized that after I compressed the valve but it was dropping enough to not allow the keepers to come off. Subscribed and BTW the Magnum will be off the road for the Year after our Canadian Thanksgiving weekend (Monday) so I'll slip the Tires in dedication to Ol Reds recovery. Danny
Redtruck-VA
Redtruck-VA
Virginia
Danny, sounds like you have something major planned for the Maggie?
Got the gaskets and bolts and installed the other eight springs so I'm ready tomorrow to bolt the head on and install the cam. Found a bad tension pulley and the new one just showed up along with some new Monroes. I'm almost ready to make some noise....
Redtruck-VA
Redtruck-VA
Virginia
Got the head back on and the cam installed. Only grief I'm having is getting the lower bolt behind the engine mount started, may have to take the mount off to get my fingers in there.
Redtruck-VA
Redtruck-VA
Virginia
Motor is about 95% complete, radiator being the only big piece to put back on. Still need to get one bolt on the header and install new front shocks.
Redtruck-VA
Redtruck-VA
Virginia
Things went well today, Mounted all the accessories including the belt and then started plugging the harness in. Had to take the AC pump back off to get to the ECT sensor. Worked at getting the hidden header bolt in and it screwed right in Must have gotten lonely not being with his batch. Rained fairly hard all morning, nasty out. Good chance of making noise tomorrow.
Merc225hp
NA
truck
gas
Nice work Sir very nice. Sorry to read about the dropped valve, did you have that jug at TDC when that happened?
Redtruck-VA
Redtruck-VA
Virginia
No, with the plugs and push rods all removed the engine rolls to BDC when air is put to the cylinder. I was just being careless, the compressor had shut down once before and I threw a wire tie on the valve stem before it became a problem. This time I wasn't paying attention and popped the valve seal off thinking it would hang for a moment. It dropped like a stone... lol
Redtruck-VA
Redtruck-VA
Virginia
Redtruck lives!... Fired up with minimum hassle. Idle good, but need to lean out the tune a little. Will run it for a couple days and see if it adapt at all.
