Davy120
- Jul 27, 2012
- 1,114
- 183
- fairchild afb
- 2003
- Hemi 5.7
That's what it sounds like, how's the crazy jay compare to the 6.1 cam?
Camo Ram
Camo Ram
Reason for mentioning pulley was more for helping with the higher than stock reving. After i sold mine to Greg I put a new OEM givin the age of the truck as the rubber around the pulley dries out over time. Was not aware of the characteristics of a UD pulley as you explained, but i beleive you and will think about that the next time i hammer the Magnum as shes got a powerbond 25 UD to spin the Crazy Spartan!
Mario your 04 is a great year for a 260 install! I like your mods list. Davey you can get 8 exhaust rods that are custom length for the Crazy Jay for 70 bucks then 6.1 on the intake side which are bang on. 6.1 springs are for running up into the 6k range and given the age of the truck like Greg said you do the seals. So the list grows. Some gaskets although reusable may be required (timing cover, water pump if having a look to check corrosion of water pump to cover, valve covers) including crank seal but if its not leakng your good.
Ok so remove the heads, ill need new studs and gaskets.
Don't remoce the heads ill need a special tool to remove the springs?
Hmm the choices hahaha
Camo Ram
