Check Engine Light
cmm47172
2008 Dodge Ram 1500 ST Regular Cab
3.7 L V6
Today the check engine light came on.
I have a 2008 Dodge Ram 1500 ST Reg Cab with a 3.7 Liter Magnum V6 engine.
I was able to retrieve two codes.
I can see p0430 and 1798.
Does anyone know what these mean and know what the fix is?
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
p0430 "Catalyst System Efficiency Below Threshold (Bank 2)"
If you have cats then it can be from a leak, bad rear o2 sensor or the cat is not functioning as designed.
Bank 2 = Passenger
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The other code looks like a trans related one. Has the trans ever been serviced?
