Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Engine & Performance
Check out my new Aluminum 426 for my Daytona
This is a discussion on Check out my new Aluminum 426 for my Daytona within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category!
What's FBO?...
Like Tree17Likes
Sponsored By: Moe's Performance
Reply
Old 10-12-2017, 06:18 PM   #31 (permalink)
Ram Year: 2005
Engine: 5.7 Hemi
Default
What's FBO?
Sponsored Ad
Register to remove this ad.
Drunken Hamster is offline   Reply With Quote
Old 10-12-2017, 07:35 PM   #32 (permalink)
ST-8's Avatar
Ram Year: 2004
Engine: 5.7
Default
Full bolt on
__________________
2004 Dodge Ram 1500 ST- 5.7L RCSB
SC 3865- Comp 260- 6.1 springs- 6.1 pushrods- Pacesetter coated LT's- Bfi #42- 4.56s- oem lsd unit- junkyard 4.7 trans an converter- 3/4.5 drop
ST-8 is offline   Reply With Quote
Old 10-12-2017, 07:37 PM   #33 (permalink)
Ram Year: 2005
Engine: 5.7 Hemi
Default
Originally Posted by ST-8 View Post
Full bolt on
That now seems painfully obvious, wtf?
Sent from my magic 5-inch
Old 10-12-2017, 07:52 PM   #34 (permalink)
Lethal Hemi's Avatar
Ram Year: 2005
Engine: 5.7L
Default
__________________
2005 Dodge Ram Daytona
Mods: 5.7L, Custom cam, LT 1 3/4 headers, 4.56 gears, circle D converter, BFI intake, Hemifever tune, Raceline billet wheels 22x10 & 24x15
Lethal Hemi is offline   Reply With Quote
Old 10-12-2017, 07:54 PM   #35 (permalink)
Ram Year: 2005
Engine: 5.7 Hemi
Default
Originally Posted by Lethal Hemi View Post
AND I CALL MYSELF A F***ING CAR GUY, AMIRIGHT??
Edit: but what's actually included in FBO? I though heads were, since they bolt on and all. Cam is a different animal, so yeah. Does it include an aftermarket ignition system? Ecu? Throttle body?
Old 10-12-2017, 10:07 PM   #36 (permalink)
Ram Year: 2005
Engine: 5.7L
Default Check out my new Aluminum 426 for my Daytona
Itís a non ending debate but 99% of racers refer to FBO as Headers, intake, pulley, TB. Thatís why on my post I stated heads cam and FBO as the other mods
__________________
Old 10-12-2017, 10:29 PM   #37 (permalink)
Ram Year: 2005
Engine: 5.7 Hemi
Default
I see. But a Pulley? Thought you only did that on supercharged builds? What Pulley do you upgrade for FBO and why on an [starting off as] N/A motor? And for that matter, what throttle body can you put on this thing as a bolt on part? Or did you just mean cable pull instead of drive by wire??
Old 10-13-2017, 03:38 AM   #38 (permalink)
Ram Year: 2002
Engine: 4.7L Magnum
Default
Not really but kinda! A My Heads cam FBO 5.7 made right at 400 rwhp and 420 rwtq and my 545rfe was strong as hell and on occasion Iíd spray a 100 shot and no issues. But I had upgraded transmission lines, cooler and deep pan with my 3800 stall. So depends on how aggressive ur 410ci will be determine if u need to go another route right away. But eventually u will cause u will get tired of transmission failures even if each other last 15-25k miles
So I don't have a 410 stroker but I'm tired of my 4.7 so I'm currently saving up for a big swap but what kind of trans would you run, one that would obviously last longer than 25k miles and not need too much modification to adjust for this trans. By that I mean like weld a new spot for the cross member and stuff of that nature. Also when I just put the stock 5.7 hemi in what's a better trans the 45RFE or the 545RFE?
Ian_Olivas is offline   Reply With Quote
Old 10-13-2017, 12:01 PM   #39 (permalink)
HemiLonestar's Avatar
Ram Year: 2003
Engine: 5.7 hemi
Send a message via AIM to HemiLonestar Send a message via Yahoo to HemiLonestar
Default
Underdrive pulley, causes accessories to turn slower and cause less drag on the engine. Putting a 6.1 damper on an LX 5.7 is cheap and easy underdrive pulley. He speaks of ported throttle bodies. Bigger bore, better shaped. Problem is, unless you have major mods that change the amount of air you're moving in and out of the engine, the return doesn't justify the cost on a stock engine.
I have yet to see someone have a finished consistently reliable hemi swap from a 3.7/4.7/5.9 even. Everyone's eyes and plans generally start out bigger than their wallets and technical ability and they find out the hard way lol. To answer your question though, if you are putting a stock hemi in, the RFE will be enough. This is where I question your technical ability to do this swap because you don't actually know that a 45RFE and 545RFE are the same trans with different programming. It's the software that makes the difference. You can take a 45RFE from say a 2002 4.7 and say stick it in a 2003 5.7 and it instantly becomes a 545RFE because of the programming (ask me how I know this). Hell even the 6sp they had for a few years before the 8sp is the same trans with revised programming.
chrisp2493 likes this.
__________________
2003 Ram 1500 QC Hemi Lonestar "Big Red" & 2006 Charger R/T "Little Red"
SRT-10 suspension, brakes and interior parts, Circle D, 1 ton trans cooler, Bilsteins, Superchips, AiRaid, Taylor shorties, McGaughy's shackles, Borla cat-back, Daytona lip, tow mirrors, SRT-10 hood.
HemiLonestar is offline   Reply With Quote
Old 10-13-2017, 12:32 PM   #40 (permalink)
Ram Year: 2005
Engine: 5.7 Hemi
Default
Hmm. Didn't know that. But wouldn't that make your power steering and a/c weaker? And alternator for that matter?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Check Gas cap light, now check engine? Batt4Christ Engine & Performance 4 03-18-2014 11:52 PM
Drop....CHECK....Caltracs.....CHECK truckin151 Engine & Performance 30 04-09-2012 02:58 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
