cold air intake
ramanator
ramanator
alabama
2006, 1999, 1995, and 1984
Hemi 5.7, two 318s and a 360
I have one of these on my wife's neon but idk how it would do on a hemi.
gunner1374
In the 405!!!
HEMI 5.7
Should be some type of gains as long as you aren't sucking in hot engine bay air. Hot air will negate any positives and may actually be worse than a stock airbox with a K&N or similar hi flow drop in. Just my experience any way. If you can block it off to pull cold air from the front or wheelwell, as Harold did, it should most definately be better than a stock box. Good luck!
ramanator
ramanator
alabama
that's what I was kinda thinking. Thanks
ST-8
I got a knock of aem Cai from eBay over a yr ago for about 100shipped. Has done it's job an even came with a tb spacer!! I'll have some use for that one day
gunner1374
In the 405!!!
HEMI 5.7
Not sure that I would waste time with the TB spacer, but please let me know how you like the UD pulley when you get it put on. I have been eyeballing a 20% UD that is supposed to be awesome, but no real world feedback yet. Thanks!
ST-8
I was talking about taping the tb for spray :)
But I will let you know. I know a couple local guys that have a u/d for there 4th gens. Just waiting for th to put on.
ramanator
ramanator
alabama
this might be a dumb question but what's a u/d lol
ST-8
Under drive pulley
ramanator
ramanator
alabama
Lol oh ok
Rokmonanoff
Tundra, Alaska
2008 Mega Cab
I didn't know either
u/d....
Thank you for all of the great information about CAI. It is next on my list (after new tires). I'll probably go with the same that Harley Harrold has.
The willingness to share helpful information here is fantastic.
Rok
:favorites13:
ramanator
ramanator
alabama
Ok im stuck between Afe magnum force or a k an n cai . I've heard alot on the k an n but the afe not so much . So any sugestions
Lugnutz
Anybody have issues with their MAP sensor after installing cold air intakes?
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Installing a CAI should not cause any issues with the MAP sensor. I'm a little surprised the subject IAT sensor hasn't been explored since CAI is about providing cooler air. I'll give a clue, Power Wire.... If the inlet air isn't as cool as you think is optimum, then consider what a Power Wire might do for you. ;)
HeavyD
Medicine Hat, Alberta - Canada
4.7 SOHC 5 SP Auto
I have used WAI (warm air intake) & a CAI (Cold air intake) on several diff vehicles.
the CAI will give more power, but the WAI will give more MPG (and I don't mean stupid hot).
Kenswartz
pittsburgh pa
I'd suggest injen power flow intake. I noticed a difference not so much in gas cause my foots always in the throttle lol intake looks great and sounds amazing at wot!
Ramrt1
Oakdale, La
2012 Ram 1500 R/T
Vararam intake, S&B, Volant, both have available ram air scoops.
Ramrt1
Oakdale, La
2012 Ram 1500 R/T
Plastic absorbs heat better than aluminum, or metal. You want to keep the intake charge as cool as possible.
