Cooling leaking?
Nesto1000
Houston, Texas
4.7L Magnum
So I think that I might have a coolant leak on me... but I'm not too sure.
Recently my truck started to overheat, opened up the hood and filled it up with just water temporarily. I was about to flush the coolant/water and put more in, but then I thought to myself that I had just changed it out less than 10k miles ago.
Sometimes when I turn on the A/C or the Heater I hear some water dripping on the passengers side of the truck. I think that that might be where I have a leak.
I would appreciate it if someone can help me out with fixing this problem.
Nesto1000
Nesto1000
Houston, Texas
4.7L Magnum
I think that I have a leak somewhere on the truck, but it's not where I first stated.
Anyways the truck's heater works better now, so it's all good.
TJ.theTech
2002 Dodge Ram
Replace radiator cap first. Could be bad causing boiling of coolant under pressure. Pressure test of system shouldn't be bad idea to verify holding pressure on its own
Sent from my SAMSUNG-SGH-T989 using Tapatalk 2
