KGBIGCOUNTRY
- Jun 29, 2010
- 13,309
- 474
- MECH, VA
- 2004 RCSB/2005 QCSB
- 5.7 / 5.7
Its gonna be a beast at the track coming up man cant wait to hear times out of it.
the pcm is always gonna try for stoich...but you can adjust fuel trims at idle and part throttle to improve performance. I was able to log my af's (not talking about wb) in closed loop with my old sc 3815...but I know 03's didn't have this option..I was thinking maybe the newer ones did..
That's kind of what I thought. My PCM pulls a ton of fuel at idle, like -20 for LTFT.
that's WAAYYYY rich...you need to pull fuel ( - numbers are rich, + numbers are lean)... I would pull the powerwire and see what it logs...
That is why I want a custom tune. I need to get some fuel pulled at lower rpm's but not at higher rpm's. The pw is still on bc at wot it is a little lean.
makes sense...safer that way..
You holding off til super chips comes out with custom tuning or swapping back to diablo f for tuning
that should make your truck run real nice
I should havemy tuning taken care of in the next couple days just gotta do the logs and send my payment in
