Does oil filter brand matter?
DTLA_RamLover
Ontario, CA
Hey everybody
I've got a 2008 5.7L 1500 and I've recently become addicted to doing all of the maintenance myself :favorites13:
I'm due for an oil change in the next week or so and I'm curious to know whether or not the brand of oil filter I get really matters.
Considering the relatively low price range oil filters run, I'm not opposed to paying more if it pays off in the long run.
Any suggestions? Thanks
charonblk07
Calgary, Ab
F1-A forged 349ci
It definitely does. There are lots of threads on the web where people have cut open and compared filter media and design. If you run synthetic and want to run longer oil changes then a fully synthetic filter media is a must. I only buy the Royal Purple synthetic filters these days but there are plenty of other quality filters out there; don't by into the name branding either, most filters are made by the same companies with a different label on the box; there's also quality differences between lines in the same brand.
I believe the synthetic oil thread has a sub topic comparing filters as well, have a look for that.
D
DTLA_RamLover
Ontario, CA
Great thanks!
Do you exclusively run with Royal Purple motor oil?
I've been leaning towards the Pennzoil Full Synthetic High Mileage but haven't made decision yet. I intend to purchase the oil and filter at the same time.
blackbeautyhemi
Lewistown, PA
I just tried redline full synthetic motor oil for the first time, quietest my motors ever been.
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Only thing I will add, is stay away from unknown name brands and obscure filters from overseas mainly Asia. In the rare event you have a filter related problem that causes engine problems, you want to be able to have a path of recourse that is either from a know major brand or a house brand through a know established retail outlet.
Just be warned, oil filter threads can turn into motor oil threads in that a lot of opinion and hyperbole of what brand X is better than brand Y. Everybody has their favorite for many different reasons. Just take it in and make your own decision because no matter what one you make, someone is gonna have problem with it.
BAMF
Southern Louisiana
2015 Big Horn
I use amsoil filter
BAMF
Southern Louisiana
2015 Big Horn
15k mile change interval
NOcasio7
Tampa Florida
I have looked into this myself recently and I have learned quite a bit. I was a mobil one oil and filter man but will now be switching to redline synthetic and royal purple filter or wix filter. Whatever you do choose and I say this from recent experience, if you want to give the K&N filter a shot... research and keep an eye on it. I personally will never buy K&N filters again. Last Sunday i did an oil change... a few days later I saw a leak under the truck, turns out it was coming from the filter where the tightening nut gets welded on had a slight crack in it that was causing a leak, switched to royal purple filter 10-48 I think and its been clean and good. Good luck with what you choose but there is a lot of data on here and a lot of good opinions.
charonblk07
Calgary, Ab
F1-A forged 349ci
Great thanks!
I run Redline 5w30 in mine but I'm also running a 17psi supercharger with water/**** injection so you can't compare mine with a stock engine, that said, a quality fully synthetic oil allows you to run longer change intervals and if you do used oil analysis like some of us you will learn how often you truly need to change your oil and get away from the 3-5000mi that is the common belief.
D
DTLA_RamLover
Ontario, CA
Thanks for all the tips and help!
I decided to follow through with the Royal Purple filter as it seems to receive consistent and high accolades.
As for the oil, I'm going to go ahead and try the Pennzoil Full Synthetic High mileage 5w-30
My truck just ticked 145k miles yesterday so I figure it'll do a good job on my older engine.
I'll likely get to changing the oil myself in the next week or two. I'm excited to get to it.
Thanks again everyone!
CorDog009
East Texas
I had ran Royal Purple for a while. I had put it in everything. Now I just run regular Mobil 1 and a Mopar filter. 134k miles and get a whopping 14-15 mpg since day one, so I'm going back with conventional oils when it's time to change the oil in the diffs/trans/t-case again.
