Engine & Performance which electric cutouts?
This is a discussion on which electric cutouts? within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category! Register to remove these ads. It's free!
gonna get some o2 simms and ecutouts and run true duals. which brand ...
01-31-2012, 06:00 PM
#1 (permalink)
Ram Year: 2002 QCSB 4X4
Engine: supercharged 5.9
gonna get some o2 simms and ecutouts and run true duals. which brand have you guys found to be the best? i have read where some have had problems with sealing issues. just cannt remember which ones now. i am gonna run them to a switch on the dash if that makes a difference to ya.
__________________
comp cam,2.02 heads,2600 stall,edel ceramic shorties,52mm fastman,sct,flexalite 180 e-fan,hs 1.7 rockers,k&n fipk,hughes airgap,aemwideband,aem boost,aem trans,msd coil,msd superconductors,msd streetfire ign,magnaflow,vortech s/c 8lbs,walboro 255pump,39lb inj.,intercooler. and a hemi durango murderd out.
01-31-2012, 07:59 PM
#2 (permalink)
Ram Year: 2002
Engine: 5.9 Magnum
I know alot of guys get the racelands. They are cheap and I'm pretty sure come with everything. Thats what I've been looking at, at least!
__________________
02 Ram 1500 SLT+ quad cab 5.9L 360 / leveled / 35 12.50 BFG all terrain ko's on 17" pro comp xtreme wheels / Led tails and 3rd brake light / sc tuned performance 91 / Efan / K&N CAI / coming soon prestige pocket fender flares (waiting for paint)
01-31-2012, 08:02 PM
#3 (permalink)
Ram Year: 2005
Engine: 5.7 HEMI
get raceland. thats what igot. its real good.
__________________
night vision HID kit, Pacesetter LT headers dual exhaust flow master 40series dumped before the axle, vararam air intake, 1.5inch leveling kit, Dakota AT^2 tires, plastidipped wheels. raceland 3" cutout, SC 3865 tuned, rocket wire, aeroforce gauge in a SRT 10 pillar with A/F ratio, color matched gill, plasti dipped bumpers.
01-31-2012, 08:19 PM
#4 (permalink)
3rd Gen / Site Mod
Ram Year: 05'
Engine: 5.7
Racelands do not support a dual system. In other words you need 2 units and open them individually. If you want duals check out dmh they have a dual setup
__________________
RamForum.com Moderator
Comp 268 / 6.1 springs & rods / Jet 180 T-Stat / Vararam / DSP - Tuned by HemiFever / Pacesetter LT Headers / Cats - Opened up to 3" in-out / 3" ORY / Cut-out / Borla XR-1 / SRT-10 Gauge Pod / Aeroforce Intercepter / AI Wideband O2 / 2800 Stall TC / Sonnax Line Booster / 4.56 Gears / Bilstien 5100's / Hellwig Rear Sway Bar / Yokohama Spec-X's 305/50/20 / Viper Alarm / Jimmy Jammers / Caltracs / DJM Drop Shackles w/ OL Spring removed / TB GW
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
01-31-2012, 08:44 PM
#5 (permalink)
Ram Year: 2012
Engine: Hemi 5.7
I had dmh low profiles on my charger and loved them.
__________________
01-31-2012, 08:50 PM
#6 (permalink)
Ram Year: 1998
Engine: Magnum 5.2
heard good things about dmh as well
__________________
College rocks, what it does to the mod budget is not.
Mod Thread-http://www.ramforum.com/f17/codes-mod-thread-15049/
01-31-2012, 09:09 PM
#7 (permalink)
Ram Year: 2005
Engine: 287
Like Ryan said if you run race land you have you use two remotes to open both.
02-01-2012, 04:52 PM
#8 (permalink)
stopped by the exhaust shop today and talked to him for a couple. he said that if he was me he would just go with one and keep my current exhaust. he said that if i go with a dual setup like that my scavaging wouldnt be right. he said i would lose some on the low end with not enough gain in the upper rpms to make up for the loose. i am thinking he wasnt b.s.ing me cause he could be making some money off me.
what do you guys think?
__________________
02-01-2012, 05:45 PM
#9 (permalink)
Ram Year: 2005
Engine: Hemi 5.7
I'm running a 3'QTP cutout and its been good.
02-01-2012, 05:46 PM
#10 (permalink)
Ram Year: 2012
Engine: Hemi 5.7
I had a charger rt before my SRT. I had dual cut out on that and with both open it felt sluggish. So yeah I believe him.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
