2004hemifever
- Jul 22, 2013
- 1
- 0
- 2004
- 5.7
Hey guys new to the forum.
I just had a question about a coolant problem I am currently having with my hemi. The truck has been rebuilt a total of 4 times already, long story short the last three have been under warranty.
But i am currently losing coolant at first could not figure out where it was going then my truck started missing and through a cylinder 5 misfire. and would hard start after sitting overnight.
I have done a compression check and appears to match other cylinders. pressure test cooling system (cold and running there was no fluctuation in pressure while running), and then the pressure slowly bled off.
The truck does have performance mods, (cam, milled and ported/polished heads, and custom exhaust)
My question is does anyone have thoughts about what could be causing this issue?
Thanks for any help.
