The hemi and 4.7 motors are very similar PCM wise. This is what makes the hemi a good motor to use. The harness you are asking about I would think is for a hemi retro install were there is no PCM installed. The 4.7 harness would need the hemi COP coil connectors wired to it's ignition harness and the injectors I would think just plug in. Knock sensors, EGR, alternator, oil pressure, water temp, IAT, CMP and CKP should plug in or perhaps need new connectors. But the point is, that the 4.7 would be looking for them and the hemi has them available to use. The 4.7 uses a drive by cable TB so connecting TPS/IAC again should simply plug in when using the correct connector. TPS for GM and/or most manufacturer TPS uses a common 0-5vdc signal. The 4.7 IAC would need to be deconstructed to determine what electrical requirement they need to work. They are a stepper motor and it might be as simple as using a 4.7 IAC motor with a GM mounting bracket if a GM TB was used. In my mind it is a pretty straight forward install. Again this is done a lot in Durango/Dakota's world and you should do all the research and have all your questions answered before starting. The needed tuning is to build a VE table to support the increase engine size and horsepower levels. Good luck..
