HylanderUS
- Oct 7, 2014
- 3
- 0
- 2003 Dodge RAM 2500
- Hemi 5.7
Hi!
New here and all that, hello
I have 2003 RAM, 2500 4WD, Hemi. I noticed the exhaust getting louder lately, and found a small leak. Not sure if I'm using the right verbiage here, so let me describe it to make sure:
Coming from the rear, there's the cat, and in front of the cat, the two (what I would call) down pipes (the pipes right after the headers) join into one pipe.
The driver side one of those is where the problem is, the gasket where the "down pipe" joins the "main pipe" is half missing.
I was going to just replace the gasket, but the bolts there are so rusted that I just have no illusion that I would get that pipe off and back on again in one piece.
So, now the question
What do I need to buy if I want to replace the driver side pipe w/ flange that goes into that main pipe? I just can't find that anywhere. I found some packages that replace the whole cat and that come with the two "down pipes", but they're usually listed for a 1500 RAM, so not sure if those would fit.
Any hints where to get what I'm looking for, and what the hell it's called?
Thanks in advance,
Thomas
Thanks in advance,
Thomas
