Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Engine & Performance
Fan Clutch Won't Disengage
This is a discussion on Fan Clutch Won't Disengage within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category!
Yesterday I replaced the Water Pump and Fan Clutch on my '05 4.7. At idle, everything sounds fine. When driving ...
Sponsored By: Moe's Performance
Reply
Old 01-07-2017, 03:29 AM   #1 (permalink)
Ram Year: 2005
Engine: 4.7 Magnum
Default Fan Clutch Won't Disengage
At idle, everything sounds fine. When driving it's a different story. When the engine hits >2500 RPMs, sounds like I'm in the cockpit of a C-130. There is loss of power, and fan speed seems to be dependent on engine RPM, regardless of the gear or temperature. New Fan Clutch is stiff while cold.
What steps do I need to take to correct this issue?
Sponsored Ad
Register to remove this ad.
Blue_Smoke13 is offline   Reply With Quote
Old 01-07-2017, 04:53 PM   #2 (permalink)
MarkV's Avatar
Ram Year: 2003
Engine: 4.7 Magnum V8 NOW with Moose Power
Default
Might be a bad fan clutch....
Sent from my SM-G900F/T/I/M/P/W8 using Tapatalk
__________________
2003 1500 Slt 4.7, 4wd, Owned
Cosmetic
Leveled - 33" Toyo AT2 - Tow Mirrors - LED Headlight And Fog Lights - 12" Light Bar -
Performance
Edge Evolution CS - Detroit TrueTrac Locker - Flex A Lite Rad Fan - Trans Cooler -
MarkV is offline   Reply With Quote
Old 01-08-2017, 03:22 AM   #3 (permalink)
Ram Year: 2005
Engine: 4.7 Magnum
Default
I pulled the fan Assembly off, and the jet in my driveway disappeared.
New felt a little stiffer than the old, not a huge difference. I think the thermostat on the fan wasn't engaging. Swapped the new one out for old and returned it.
Problem solved for now, I guess.
Reply
Bookmarks
Tags
4.7, cooling fan, fan clutch
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
A/c clutch Jaeger42 General Discussions 1 06-07-2016 08:21 PM
Part Time t case slow to disengage and bangs gassyplumber General Discussions 12 01-13-2016 05:58 PM
Clutch Fan Won't Disengage wyo2track Heavy Duty 38 01-02-2016 04:14 AM
Clutch isn't going in all the way K.Adkins_22 Engine & Performance 3 07-01-2013 12:59 PM
A/C clutch Muddytazz Engine & Performance 2 02-17-2013 09:54 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
