steven4177
- Nov 27, 2016
- 25
- 0
- 2005
- 4.7
purchased a 05 ram 4.7 a week and a half ago. it had water in the cylinders so figured blow heads that fine ill buy it and fix it. get it home pull it apart and get the heads to the shop. get heads milled/resurfaced get back home install new rings, bearing, oil pump, timing chain guides, tensioners, gears, chains, and all new seals. get it all reassembled and truck wont start. timing is dead on. get to checking and pull spark plugs. have water in all eight cylinders. yes heads was torque properly and in correct order. blew water out drained radiator and as much of the engine as i could. tried to crank truck and it started up sounds great. pour 1 gallon back in truck and no start water again in cylinders. pressurize cooling system and hear hising. get a light out and take a look to see where it coming from and behold water/air bubble coming from around the head gasket on both heads. wtf. why didnt it seal. any ideas
