which headers?
4X HEMI
Lancaster County, PA
hahaha You get what you pay for, you want a great set of headers that are specific for the Hemi and made to fit with no cutting or altering ... thats the way to go. Your going to save up $400 may as well save a little longer
reefguy89
reefguy89
laurel de
would that even work for states that test for emissions?
bigtigga84
dela....where?
keeps the cats. i would assume keeps o2 sensors, can't tell. as long as it doesn't upset the sniffer and doesn't throw codes that they can see i don't see why it wouldn't pass.
bigtigga84
dela....where?
bigtigga84
dela....where?
read the install above. says it keeps the o2 sensors. i can't see this not passing our emissions test.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Exhaust IMO is one of those mods that whatever you do will pretty much be an improvement over stock. With a couple of exceptions. Read about how mufflers work and determine which muffler you want. Headers all out flow stock manifolds. Use two cats and select what cats you want. 03 OEM cat is the best I have found. Figure out what you want your pipes to look like and put it together. If you read my post in your other thread then you will know it is all a compromise and whatever you do will work. Good luck....
Edit:here is my header thread. It has excellent advice and great pictures thanks to the forum. http://www.ramforum.com/f50/pacesetter-lts-3371/
bigtigga84
dela....where?
i did lol, just didn't go back and re read it. sooo..... anybody want to buy a magnaflow y? lol
4X HEMI
Thats the way I see it, with the Dynatech everything is included. All the other ones don't include the extra stuff you have to buy. So for the price, you can't beat them either.
RubberFrog
i gotta get another fukken job..... you guys kill me lol. in another thread i had going about exhaust. frog was sayin that if you add headers, x pipe and duals are a better set up. just tryin to throw all ideas out there.
I still stand by that!
amdwilsns01
